Threads: 30
Threads: 573
It is 1800 ohm FIELD coil. Your voice coil is likely to be from 0.7 to 4 ohm.
Now that you don't have the speaker and probably missing your output xfmr too, just get a proper size speaker and match the transformer.
The sch is similar to Philco 20 but with A output stage so a speaker from 70 could do.
Threads: 269
Or a Philco 90 w/single 47. I think I see one.
Threads: 573
Yep. Thy are practically the same. Or are the same.
PS. Make sure if it is a 90 speaker it is from the one with a single 47 out, not a pushpull one.
Threads: 30
Ok! I'll just steal the one closest to the Phonola right now... ;)
Threads: 30
So, I did some measuring, and comparisons... and a Philco 70/90 speaker won't physically fit into the cabinet, between the decorative bolts. Actually, none of the multitude of speaker I have around here will fit the bolt pattern they used.
So, I did a bit of research, and using a picture of a similar set I found online, and a same-year battery set I have here...it seems that Grimes was using Utah speakers, made by their Canadian division.
Threads: 30
I have located a speaker that will fit. But, the field coil is 2600 ohms, which puts it 800 ohms higher than the original. I know that one can roughly go 300 ohms higher than the original value, without affecting the B+ voltage too much. But those calculations are also based on a +- 110 volt power source. Out here in rural Alberta, where I live, the line voltage is running 128 volts. Does anyone have experience using a speaker with a higher field coil value? Maybe the B+ will still be ok? Any issues in doing that, which might affect the power transformer?
Threads: 573
Brad, you can put a power resistor in parallel to bring the value in line with requirements.
Yes you might want a bit higher value, maybe 2000 ohm as the resultant from the parallelling.
Threads: 54
Brad;
Try looking through some of the U.S Radio and TV schematics, some of the Phonola sets from that era are Kitchener built clones of those sets, I have one that is basically a gothic Gloritone in a slightly different cabinet, and says "Dictator" on the escutcheon rather then "Gloritone".
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
Welcome to the Phorum!
:wave:
There are currently 1478 online users. [Complete List] » 3 Member(s) | 1475 Guest(s)
