Philco 43 Grille Cloth
This is my first post on the Philco forum. I've been a radio collector since I was 10. This is one of the best radio forums on the internet!
I am looking for a photo of a model 43 that has the original grill cloth, or something very close. The 43 I purchased a few days ago has something that looks a little like part of a black air filter!
Hi and welcome,
http://philcoradio.com/gallery2/1932b/#Model_43B
Something like that. Nowdays there isn't a wide selection to chose from for replacement cloth.
Welcome to the Phorum!
Icon_wave
And it also depends on which 43 cabinet you have.
If it is the 43B cathedral, it originally used the same cloth as Philco 70 and 90 cathedrals.
Thanks for your help!
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
