Emerson 267
Looking for schematic/info for an emerson 267 (CG267?) radio
Found a cg-268@http://www.nostalgiaair.org and a cm -267 http://radiomusem.org/r/emerson_cm267.html
Kent.
Yeah looking for component values.
Someone's been into this and god knows where to start..
Thanks Kent
I looked Are you sure this is model not chassi number. Check see if the 268 might be same schematic.
This comes up at NostalgiaAir on a 267 search.
http://www.nostalgiaair.org/PagesByModel...004951.pdf
http://www.radioatticarchives.com/radio.htm?radio=4792 is this your set . If it is this guy maybe able to help http://www.radioattic.com
Or this http://www.radioattic.com/toppo
Yet the Radioattic pic is the correct radio.
I did get the number from the chassis as all the decals are gone.
I printed out the CM267 schematic and it looks more correct than what I had. Will have to investigate.
Thanks guys
Ilooked through all schematics up to 1953 no cg267 .Ithink the cg268 is the one you need.
12' Philco
12' Philco
12' Philco
My last cabinet for this year
Philco 41-608 changer coupler
Hi Morzh, I've searched using Mondial as the user name with various keywords such as 'coupler', 'motor', 'idler', 'p...alangard — 08:31 PM
There are currently 4343 online users. [Complete List]
» 1 Member(s) | 4342 Guest(s)
