37-10 Question
Hello. My father is recapping my 37-10 and he wanted to know if the negative connection on cap 84, which is a double,20 mfd and 10 mfd, and the negative on cap 82 are common. Thanks for any advice.
Regards,Darrick
Yes. And note that it goes to the center tap of the power transformer, not to a chassis ground. The positive of the 10uf (84A) goes to chassis ground.
-Bill
Thanks Bill. Would you happen to have a diagram of cap 84 and 82 in circuit? He recapped and when he plugged it in, the 5Y3 rectifier was sparking. He quickly unplugged it. Thanks for the help.
Regards,Darrick
The only thing I can offer is a link to Nostalgia Air.
http://www.nostalgiaair.org/resources/
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 2113 online users. [Complete List]
» 1 Member(s) | 2112 Guest(s)
