Connecting Test Equipment to AA5 radio
It's been a few years since I worked on AC/DC AA5 sets. I use an isolation transformer when I work on them. I have forgotten how to safely connect test equipment such as a signal generator and VTVM to these sets. I have a Heathkit VTVM that has a 3-prong cord. With the radio connected to the isolation transformer, how do I connect the negative test leads to the set?
With the isolation transformer you can connect the - lead right to the chaiss. Without the use of an isolation transformer you can measure the voltage from earth ground to chaiss ground. If you get 120vac flip the ac plug around and you should measure a small amount of ac, the difference from neutral to earth ground. Just make sure you don't have 120v from the chaiss to ground and you will be fine.
Poor Man's Method = Battery operated DMM and link coupling from the signal generator to the loop antenna. Icon_smile
I haven't found it so much with radios but DMM will drive you nutz on TV's. If the measured volt isn't pure (mixed with a little rf or ac) the DMM will give an incorrect reading. Also vom's and vtvom usually are what the manufacture used way back when the set was built to make up the voltage charts for testing. I do like the DDM for resistor checking.
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 2130 online users. [Complete List]
» 2 Member(s) | 2128 Guest(s)
