condenser/resistor question?
I am about to recap a mod. 511, what wattage should the wound resistors coupled to the (3) .1 uf /100ohm by pass condensers be repaced with after I remove and repace the .1uf half of the condenser?? I am attempting to rebuild the original part, (if possible) but if the resistor is larger than 1/2 watt I dont think there is enough room. Any input would be greatly appriciated. Thanks
If this is one of the Bakelite capacitors, 1/2 watt should be fine.
Rod
hotrod Wrote:If this is one of the Bakelite capacitors, 1/2 watt should be fine.
Rod
Well, they are not the bakelite type like in the mod. 70 onward, these are large (about 1/2" diam. X 1 1/4" long) round paper type caps with the same tar type filler as the block type. but the risistor is thin wire wound around the outside from terminal to terminal. kind of like a small coil form. Thanks, Todd
I know nothing about any resistors like that so hopefully Ron, Chuck or someone else who knows will chime in on this. I've seen wire warped around capacitors in Philcos before but these were use to block RF.
Rod
1/2 watt would be fine. Quick math:
Power = current squared times resistance. p/n 17 would be the worst case since it carries load for all three tubes. Figure 10ma for each tube. That's far above the worst case!
So 30ma total, or .03 amps. .03 squared is .0009. Multiply that by 100. Result is .09 watts.
These resistors aren't doing any voltage dropping to speak of. Their main purpose is to provide some isolation between the stages.
GL,
Bill
exray Wrote:1/2 watt would be fine. Quick math:
GL,
Bill
Thanks for the info, I have been collecting philco's for years but have recently started electronics restoration. I service H.V.A.C. for a living and one thing I have found is that the schematics in the heat and air equip. are accurate to if it shows a conection at a certain point that wire can be traced straight to that point but in these radio's it is harder(atleast for me) to trace a conection because it may jump across 5 different terminals/conections before reaching the point of A to B that the schematic shows. But with time I am sure I will get it down. Again, thanks for the information.
Todd
Some folks, 1930s RCAs as an example, included a pictorial parts AND wiring layout in their literature. It really is helpful for new and old alike.
You'll get used to the schematics. In the long run they make the most sense electrically with the least complexity. Err, well most of them anyway!
GL,
Bill
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
