Zenith 5S042AT With A 25-Cycle Transformer
I keep running into export model radios. My first was a Philco 37-670 tombstone I picked up at a yard sale for $4.00. That's still in progress, restoration wise. The latest is a Zenith 5S042AT I obtained off eBay. Just got a Rider schematic for it today and noticed that the transformer is rated for 25 cycles. Is that going to cause problems on 60 cycle current? (Both of these radios have switchable transformers for 110 and 220 VAC input.) Thank you.
You should have no problems running your radio on 60-cycle. One plus is the transformer is heavier, and will run cooler than the 60-cycle transformer.
Carl
Northern Panhandle, WV
Thanks for the reply. You are right about the transformer size. It is huge -- bigger than anything I've ever seen on a table model or tombstone radio.
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
