Philco Model 70 questions
I recently acquired a Philco model 70, the serial number is A22192. How early is this in the production run? It does have the copper Mershon capacitors. Also, one of the 24A tubes was replaced with a 35, should I replace it with a 24A. The radio works great with lots of volume! Thanks.
Here are some pictures.
Nice clean chassis!
Could you tell any difference in the operation after replacing the 35 tube with a 24A? I have often wondered why Philco didn't use type 35 tubes in the front end since the volume control varies the bias.
M R Radios   C M Tubes
(03-20-2018, 11:19 AM)Steve Davis Wrote:  Nice clean chassis!
good point
From what I've read the 24A doesn't lend it's self to being controlled by varying the control grid voltage hence it doesn't work well in a set w/avc. The 35 has a different cutoff range of voltages that will have a greater effect on it's gain.
I just tried the 24A, no difference. It is the second detector. When working on a new radio, I usually use a Kill A Watt meter to give me some information, all appears fine.
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
There are currently 1118 online users. [Complete List]
» 4 Member(s) | 1114 Guest(s)
AvatarAvatarAvatarAvatar
