What did I get myself into?
Threads: 1
City: Mount Jackson
State, Province, Country: VA
I have the tools, except the signal generator. I have looked at the tiny print parts list. I am sure, being unfamiliar, i will not get it all right. I wonder if there is a list or one stop shop for all the components that need replacing before powering on?
Threads: 270
In terms of caps you'll need:
5- .047uf@630v
4- .25uf@630v
1-.01uf@630v
1-.01uf@1600v
3-.015uf@630v
1-.5uf@630v
3- 10uf@ 450v electrolytic.
They can be had here http://www.tuberadios.com/capacitors/
You probably want to replace the power cord. Repro is available here http://www.radiodaze.com/power-cord/ but is sold in 25' lengths. Also some small heat shrink tubing is good to have but the couple of sources I use are out of stock but you can source it locally. You could get the caps from Radiodaze but I think Sal's prices are better.
Now I think I've got it!
Threads: 1
City: Mount Jackson
Thanks for the info. and pardon my ignorance, but what type of capacitors are these? besides the electrolytic of course.
Threads: 270
No problem their film caps. Typical I get the axial lead ones.
Threads: 33
(06-18-2018, 10:50 PM)brianbbs67 Wrote: I have the tools, except the signal generator.
Hi Brian,
I have a signal generator that I'll give you; just pay postage.
Threads: 114
City: Sneedville, TN
here are links to the various places I order parts:
http://www.radiodaze.com/ Good source for repro dials as well as other components
https://www.tubesandmore.com/ Lots of components, I often order from them, especially 630V axial poly caps
https://www.justradios.com/ Another good source for condensers, resistors, and more
These are a few that should get you started. I'm sure others here will; have other resources to recommend.
Threads: 1
City: Mount Jackson
Thanks, what is shipping? Brad
(This post was last modified: 06-20-2018, 11:12 PM by brianbbs67.)
Threads: 1
City: Mount Jackson
Everybody keeps telling me how rare this is. How rare is a 43B, really?
Threads: 33
Well, it's listed as "A" for rarity rating in the Philco book...and I've never run across one personally, in 30 years of collecting...
I'd need your mailing address. Then I can get you a postage price, and you can decide if you want the generator.
Threads: 270
I could probably help you out w/ a generator too. I tripped over a E-200-C the other day that I don't really need. If you like I'll give it the once over to make sure it's working and replace the caps in the p/s. Can have it for shipping. I'm just north of Philly and would guess the weight is abt 15#s boxed.
[Image: http://i28.photobucket.com/albums/c208/t...-200-C.jpg]
Threads: 437
City: Boston
One thing to like about this hobby and especially this Phorum is how helpful and nice the members are, I am always impressed with the level of helpful support and kind words. Good advice abounds.
Threads: 1
City: Mount Jackson
(06-20-2018, 10:27 PM)Brad Winder Wrote: (06-18-2018, 10:50 PM)brianbbs67 Wrote: I have the tools, except the signal generator.
Hi Brian,
(06-21-2018, 09:08 PM)Paul Philco322 Wrote: One thing to like about this hobby and especially this Phorum is how helpful and nice the members are, I am always impressed with the level of helpful support and kind words. Good advice abounds.
I am impressed already with the advice and generosity.
Threads: 1
City: Mount Jackson
(06-19-2018, 07:24 AM)Radioroslyn Wrote: In terms of caps you'll need:
5- .047uf@630v
4- .25uf@630v
1-.01uf@630v
1-.01uf@1600v
3-.015uf@630v
1-.5uf@630v
I am guessing the .5uf is a 0.47uf? And the 0.25uf should I use the 0.27uf? or 0.22uf? Thanks
Threads: 270
You guess correctly. Original tolerance was +/- 20%. Values are not particularly critical w/these caps.
Got ur generator apart, don't think it's ever been cracked open. Has a nice musty aroma about it. On
to the caps.
Don't it you are finicky abt appearance if so the cabinet has some surface rust but a little bit of black
wrinkle spray paint wouldn't hurt. Front panel is good as it's aluminum.
(This post was last modified: 06-22-2018, 05:45 PM by Radioroslyn.)
Threads: 1
City: Mount Jackson
(06-22-2018, 05:44 PM)Radioroslyn Wrote: >I am guessing the .5uf is a 0.47uf? And the 0.25uf should I use the 0.27uf? or 0.22uf? Thanks
to the caps.
I am function over form especially for tools. I am sure it will be fine. Thanks again.
There are currently 1924 online users. [Complete List] » 2 Member(s) | 1922 Guest(s)
