37-602 Cap question
http://www.nostalgiaair.org/Resources/207/M0013207.htm
Does #35 seem like a bad idea? To my way of thinking it would couple 60cy ac (hum) into the dc hv. Typically it would be from the plate of the 25Z6 to B-.
Tnx!
I'm thinking #35 acts like a noise suppression cap that is placed across the line. It us a small enough value to be able to pass hash on the ac line but not much 60 hz component into the dc power supply!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
The reason I mention it is that I had a set that was recapped by someone that miss wire a cap in this fashion. Should have been across the line not across the rectifier. It had a terrible hum. After checking the tubes for shorts and the filter caps I saw a cap across the 25Z5 socket wasn't shown on the diagram wired like that. Rewired it to B- and all was well.
I know I've seen another set wired like this that I've worked on, can't remember brand or model. Maybe your cap is fairly leaky. No harm in rewiring it across the line with appropriate X safety cap.
Ron
I see no good reason for that cap. I would try the radio with and without the capacitor.
M R Radios   C M Tubes
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
