Threads: 18
City: Cromwell
State, Province, Country: CT
I have always wanted a really high end console radio that I could actually afford. The 1000Z, Baby Strats, Scott sets were pretty much out of my range. I got lucky back in October 2017 and I purchased a 38-690 locally here in CT from an ARF Member. It was only a 2 hour round trip and my brother in-law helped me get it home. The radio was sold in operating condition, but there were issues. Knowing that I was planning on a full restoration, I would tackle each item one at a time.
I did a post in the refinishing thread when I was working on the cabinet, but I figured I'd show the complete radio project from start to finish.
Here is a list of what needed to be done.
Repair the previous electronic restoration. Many bad solder connections were found, and caps were missed. Also many out of tolerance resistors, and 2 candohms that will be replaced. Note: There were no paper caps left for me to restuff, so I left it alone and stuck with modern caps.
Stuff the electrolytic cans with 630 V film caps.
Rebuild the RF sub chassis. only two caps were replaced and all the rest were original.
Paint the rusty main chassis, sub chassis, and power/amp chassis.
Repair the cracked dial. It was spinning loosely.
Repair the audio muting switch.
Perform an Alignment.
Refinish the cabinet. A poor attempt at refinishing before left me with a layer of polyurethane to remove.
Here are the before pictures. More to follow.
Tony
Threads: 18
City: Cromwell
Threads: 573
Before pics are not bad at all. This radio is in good shape.
Threads: 1
City: Brooklyn
State, Province, Country: New york
I have this same model. Mine is just slightly different. Mine has a round knob in the center of console & i also have a brass tag on the front. It says exact replica of the ten millionth philco built for walton jones.
Cant find any info on the tag. Yours looks great.
Threads: 18
City: Cromwell
Threads: 18
City: Cromwell
Threads: 18
City: Cromwell
Mike,
The original pictures don’t show the runs on the front panel well. But that was the point where I decided to just refinish it.
Tony
Threads: 27
City: Petaluma, CA
Absolutely beautiful work, Tony! All aspects of your restoration are top notch. A radio such as that deserves nothing but the best and that's what it received! Even my wife would allow that beautiful console in the house!
Craig R
Threads: 9
City: Monroeville, PA
Great job! The radio looks really good. How did you paint the chassis? Did you remove everything and spray it or did you use a brush to get around things.
Threads: 15
City: Fort Worth
State, Province, Country: TX
Wow! Your time was well spent on creating a masterpiece!
Threads: 18
City: Cromwell
Hi Bill
I used Rustoleum Satin Nickle Metalic spray paint.
https://spraypaint.rustoleum.com/product...ray-paint/
I took of the major components off the radio and sub chassis. The IF transformers and all coils had the covers removed and then they were masked off. I took the time to block off any openings that the paint could get into. Metallic paint under a chassis near wiring could have a bad outcome.
I put wide masking tape over the tube sockets and cut off the excess with an exacto knife leaving a small disk over just the socket. Also, the piece that the tube shields go over was cleaned and masked off.
On the amp chassis, I removed the caps and filter chokes as the needed painting.
I masked around the power transformers and painted them on the chassis. Then they were masked off and the chassis was painted.
The tube shields were painted with a chrome paint. Maybe not as shiny as original, but better than they were.
Took some time, but the outcome was worth it. I couldn’t leave the rust showing when the cabinet was going to look nice.
Tony
Threads: 1
City: Mount Jackson
State, Province, Country: VA
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 09:24 AM |
No, it's not a problem, just during certain condition it could show up.
Yes, an internal tube short could do that too.
...morzh — 09:13 AM |
You sound guys are never satisfied. :crazy: :clap:RodB — 09:10 AM |
I got some new ceramic octal tube sockets installed and also tried some different coupling caps.
The results:
The go...TV MAN — 08:42 AM |
There are currently 1093 online users. [Complete List] » 1 Member(s) | 1092 Guest(s)
