Hi Fi tube amp kit from China PT 2
Threads: 78
City: Annapolis, IL
Ok all, here we go! Round 2 on the way! I have on hand another tube Amp kit from China. This one is similar, but different from my build a couple years ago. With winter just around the corner, and the shackles about to be removed from work for the season, I am gearing up for another interesting build. The good thing is that I have experience from my previous build that will transfer to this project. It is a 2 channel single ended amp that uses 6L6 output tubes, 12AX7 voltage amp and 5Z4 rectifier. This is a simpler kit with less components. Different layout. I am going to involve my 12 year old son in this build and hopefully spark his interest in electronics. I'm planning to do my own layout and make a set of step by step instructions, and see what happens.
Upon unboxing, this uses a fairy robust power transformer and output transformers. The chassis is stainless and fairly heavy. It also includes a choke, tubes, and components. The tubes are obviously China. 2 items that are not included in this kit are the power cord, which is a common computer type cord, and the bottom cover. It just includes a schematic on one channel and the power supply. Not too impressive, so that will get re-drawn.
I just love the feeling and anticipation of opening a kit box like this and looking at all the goodies inside and know the experience and satisfaction of enjoying the completed project for years to come, knowing I built it! That is an experience that is all but gone in this day and age.
What's in the box? OK, take a look!
I already know that I should order a good set of speaker binding posts. Follow along and enjoy as we start the build. I have other projects in the works also, so this will be on and off.
Tim
Threads: 553
City: Jackson, NJ
Tim
Also, see what electrolytics they gave you; if you are suspicious those are not the reputable brands, buy them yourself.
Threads: 44
City: Menlo Park
State, Province, Country: CA
Nice project - and great idea to involve your lad. Reminds me to lure my son in with a crystal set project. I have all the bits.
Cheers
Ed
Threads: 18
My first kit was an Eico HF20. Yeah, I'm that old!
Threads: 553
City: Jackson, NJ
(09-04-2018, 02:16 PM)codefox1 Wrote: My first kit was an Eico HF20. Yeah, I'm that old!
My first (and only, so far) restored amp is a pair of HF22-s.
Eico made some good stuff.
Threads: 69
City: Kansas city, MO.
[Image: https://i.imgur.com/M0ZdGIZ.jpg] Should be a fun project Tim and good idea to get the young one involved.
Looking forward to your thread on it.
I built a tube amp last March from scratch using the plans I got online from Blueglow Electronics.
Never built one before and it was a good learning experience.
Here's a couple pics of it. It uses 807 tubes for the output.
[Image: https://i.imgur.com/C7KJiR6.jpg]
[Image: https://i.imgur.com/6RP5jFp.jpg]
[Image: https://i.imgur.com/luk6EHn.jpg]
Threads: 78
City: Annapolis, IL
You have a point on the E caps Mike. If I recall, I think I upgraded at least the input cap on the power supply on my previous build, but I may upgrade all the E caps for reliability. For sure going to upgrade the wiring. All blue and stranded not going to fly. I would like to come up with a bottom cover for safety. Thinking on that one. I'm sure it is available already made if I know where to look.
KC, very nice build. Thank you for sharing!
Tim
Threads: 51
Wait!;
Hammond is getting some of their transformers made in China now? That isn't very nice given that their prices are usually the highest, more then Edcore or the Mexican ones AES sells. You might as well buy generic China ones and pocket the difference.
As for the filter caps, if you are using chokes anyhow, use large film caps like Solen or Panasonic, the China mystery brand ones may work for a few years, but they do not have the best reputation.
Arrn
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM |
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM |
Tim,
nice write up and thanks for sharing !!
Sincerely Richardradiorich — 02:47 AM |
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM |
Shadow Meter Bulb
Phorum members, I am trying to find the bulb # for PHILCO Shadow Meter part number 45-2180 that is from a 37-640 chassis...georgetownjohn — 06:53 PM |
Philco 41-608 changer coupler
3D-printing...short of machining, of course.
Or molding.morzh — 05:20 PM |
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal piec...alangard — 05:07 PM |
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
