Thinning Mohawk M608-4226 Grain filler
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Guys I got my supplies from Mohawk and have begun the process on my 40-158 cabinet. I have it sanded and sealed and tomorrow I plan to do the grain filler. I have not opened the can yet, so I'm not sure of the consistency, however I did not know it required a specific thinner from Mohawk if required. They call it Grain Filler Solvent M608-106 and I don't have any. Is there something I can purchase locally to mix with it to thin it if required? Paint thinner, lacquer thinner, etc.? I don't know what the base is. Is anyone using this filler using anything other than the Mohawk Grain Filler Solvent? Thanks!
Gregg
Threads: 276
City: Wilsonville
State, Province, Country: OR
I have not used that grain filler so hopefully someone with direct experience will offer some advice. In the absence of anyone else responding.... The MSDS for the Mohawk solvent lists petroleum distillates and aliphatic petroleum distillates as the ingredients. Mineral spirits is also a petroleum distillate although perhaps a different fraction or mixture than the Mohawk solvent but would probably work for you.
Threads: 22
City: Kewanee
Thank you Bob! I will give that a shot.
Gregg
Threads: 76
City: Winter Haven, FL
I use Timbermate. http://www.timbermate.com.au/. It's water-based. You can use it thick, right out of the container, as wood dough, or thin it to the consistancy of a milk shake for a grain filler. It drys fast, sands easy, and accepts any kind of stain. And there is no waste, because what ever is left over in your mixing tub can be re-constituted with a little water. It's great stuff!
Pat
Threads: 276
City: Wilsonville
yep...I've used Timbermate as well!
Threads: 269
If you haven't opened the can, inside the filler is very thick and the solvent has migrated to the top. I use a small container, scoop out some of the filler and add some of the solvent from the top to mix and thin. Don't think thinning will be an issue till you get near the bottom of the can if then. As Bob mentioned oms is a good choice if you do need some extra solvent.
(This post was last modified: 10-08-2018, 12:37 PM by Radioroslyn.)
Threads: 22
City: Kewanee
Awesome, thank you.
Gregg
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
Welcome to the Phorum!
:wave:
There are currently 1353 online users. [Complete List] » 1 Member(s) | 1352 Guest(s)
