BV-613 various questions
Hi David and welcome,
You might try sending Richard an email thru the Phorum. Seems he has the info you are seeking. If he still has the same email address you've got a chance to get a hold of him.  If it was built here in the states it may have an equivalent set that was produced for the auto industry or something very close. Would require a bit of researcher to sort.
Good Luck!
de N3GTE
Thanks Terry! That's the radio in the picture. I was surprised to see the wire aerial - mine has had a car aerial type socket installed which I thought was original.
I'll email Richard for the details.
Thanks again
David
M0IDF
Hello! I am new to the forum. I have just purchased this green radio. I don't know much about the conditions it is as it is sold as is. I have not received it yet but I would like to show you some pictures. I can't wait to return to life this little puppy
This is what the seller reported:
Quote:I have tested the radio with 6VDC ,the vibrator pack is working,buzzing away but there is no sound output.
I also noticed that the RF valve (ARP34) does not seem to be lit up like the rest of the valves,which i (think) maybe down to a failure of one or more capacitors and some of the capacitors look to of been replaced at some point,i get the feeling this was a project that somebody never got around to completing.
The radio does need a replacement DC lead on it as the cloth covered one is past its best (see pictures).
The radio does have the odd mark as does most military equipment.
Thank you
Ok. I managed to clean the contacts on the vibrator and it started to buzz.
After that still no sound. I checked tubes with an injector but there was nothing. I suspected the speaker was not ok. After resoldering a bad contact on the solder pad of the speaker and changed a capacitor on the antenna stage iit os back to life
https://youtu.be/Esm3MfTy-a4
Welcome to the Phorum Cesardeluxe!
Icon_wave
Nice video!
Glad you got it revived. I'm a little surprised that your able to hear much programing down in the LW band. Here in the states there's very little to hear, a few beacons and a lot of noise.
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
Philco 42-390, code 121 speaker
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
There are currently 4708 online users. [Complete List]
» 2 Member(s) | 4706 Guest(s)
