Final inspection Nov. 1940
Any advice on a source for a parts list for a PT-2.
Hello. See if this is what you need.
https://www.tubesandmore.com/sites/defau...pg14-1.png
Looks like the same animal KCMike, thanks. Label on the set says PT-2 with no 42 prefix so I wasn't sure and NA lists a PT-2 but it only shows the schematic.
Larry
Found this, hope it helps. David
thank you David
Larry
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
