Grunow 654.. No Audio
Just recapped.. turned on and at 100 Volts in draws 400 Ma..
B+ to ground is approx 310 Volts DC..
No audio.. When turning volume up and down get scratches.. No noticeable Hum..
Can scan schematic . Replaced the Bias cell with Watch battery.. Plus to Ground..
Skip
OK Here are schematics..
[Image: https://farm5.staticflickr.com/4843/4518...c178_b.jpg]
[Image: https://farm5.staticflickr.com/4822/4518...af0e_b.jpg]
[Image: https://farm5.staticflickr.com/4828/4518...ee59_b.jpg]
OK  On second picture  The Black and Yellow leads were reversed.. I put them to match the schematic so the Resistance of field coil would be right.. Did I goof???
Skip
When touching 2nd det cap or the output tube's grid, is there hum?
Are there voltages on plates?
Ok  Stupid mistake again.. I forgot to install a resistor.. No voltage to OSC.. After install worked correctly..
Next Question  Where is the best spot to hook up my VTVM to measure the AVC Voltage?  Cannot get yo speaker voice coil to put on my output meter..
Skip
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 811 online users. [Complete List]
» 1 Member(s) | 810 Guest(s)
