Need the 37-640 Speaker cone dimensions
Hi,
I need to recone my speaker it seems to have a double coil. I was wondering if anyone had the proper dimensions so I can order a kit for it? So far from what I can see, I have 6 1/2", by 1" voice coil opening, but am I measuring right? And I'm not sure about the depth.
I sourced a cone with a store on the net but he said that the depth is very critical.
If anyone has the exact measurements for this type of speaker I would appreciate the info.
Any help or information that can educate me on this would be greatly appreciated.
Thanks!!
I would send it out for repair, but being from canada the ressources are very limited to non existent from what I can see.
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
