Nathan's 38-116XX Restoration
Threads: 48
City: Shenandoah,
I don't understand why the electronics industry needs to make reading the value of a cap such a chore. I mean, what was wrong with the old way of writing .15mfd. on a cap instead of 154? This new way is more confusing, more chance of making a mistake! They have to print numbers on it anyway so why the need to complicate things? Just a pet peeve of mine!
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
(This post was last modified: 01-07-2019, 08:08 AM by 462ron.)
Threads: 1
City: Georgetown, IN
Thanks for sharing the brown hot glue stick source. In the past I used normal white hot glue and would top the end of the caps with a little bit of bees wax. I like your method much better!
For the butchered tube shield bases check with Gary at Play Things of Past. I had the same issue on my 38-116 and Gary had several of these bases at the time.
Threads: 49
City: Allendale, MI
(This post was last modified: 01-07-2019, 11:14 PM by rfeenstra.)
Threads: 212
City: Seattle
State, Province, Country: WA
@r462ron - ![Icon_lol Icon_lol](https://philcoradio.com/phorum/images/smilies/icon_lol.gif) yeah not so easy for us poor humans. I imagine they did that due to space constraints. It also gets more error-prone to count zeros rather than significant digits + multiplier. Think trying to separate 0.00047uF from 0.0047uF - as opposed to 471 from 472. Of course they could label in units (pF/nF/uF etc.) which would make the zero problem better.
@Jeremy S - Yes! BTW - thank you for your great 38-116 restoration page. You really put in some work on that one and the result was amazing. I do have some replacement tube bases. On the RF subchassis I was able to bend them back into more or less original shape. I am still thinking about what to do with the bent bases on the main chassis - mostly the best way to attach them. I see you used 6-32 flathead machine screws which seems like a good choice. The only limitation I can see is for grid cap wires that pass through the rivets - would have to drill a new hole for those I guess.
@rfeenstra - That's the idea! I have been trying to document everything to help with your 37-116 restoration since you said you were thinking about starting it. ![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif) I've previously restored a 37-116 and the two sets are quite similar although I would say the RF subchassis of the 37-116 is a bit more difficult (sorry!) as it has more caps buried in the middle of the bandswitch. The best advice is to just go really slowly and carefully and take a break if you're feeling impatient. The 37-690 uses the same RF subchassis as the 37-116 - so you can see pictures of that in my 37-690 restoration thread. There are a number of other good threads on the 37-116 - so be sure to read through as many as you can find. Your 37-116 looks to be in very nice shape.
Threads: 212
City: Seattle
Threads: 49
City: Allendale, MI
Nathan, the photo of the coupling shows a fair amount of "contamination" on the plates of the tuning cap. Do you clean those? If so, how? If not, does it affect the performance of the radio?
Threads: 1
City: Mississauga
State, Province, Country: Ontario
Excessive dirt, corrosion or stuff like tar from a smoker are bad for performance of a tuning capacitor. There are small make-up applicators that are suited to applying cleaning chemicals in narrow spaces. Even if you don't get it all off, it will clear dust bridging the rotor and stator plates and that may get rid of scratchiness during tuning. Alcohol or various types of contact cleaner would work here.
After this, you clean off the bearings and lubricate them and then you clean the shorting fingers that ride in the groove in the tuning shaft.
Make sure you have contact across the straps that ground the shield sections between the capacitor sections.
Be sure the fibre pieces that hold the stator are free of dust.
Threads: 212
City: Seattle
Thanks for the info amptramp. And please don't worry guys - I'm on it.
I would say that it looks worse in that pic than it really is. Performance also doesn't seem to be affected. But I'll see what I can do and report back.
Threads: 212
City: Seattle
I've been working on repairing the dial. Here's what it looked like:
[Image: https://farm5.staticflickr.com/4827/4565...8f07_z.jpg]
You can see the previous repair to reconnect the inner ring to the dial using some glued on paper strips. The inner ring is also broken.
Goo Gone is my go to for cleaning dials. It was also good for removing the prior repair:
[Image: https://farm8.staticflickr.com/7831/4594...97b6_z.jpg]
My plan was to use epoxy to repair the inner loop first - then attach it back to the main dial.
I used sandpaper to roughen up the edges where I would glue things.
[Image: https://farm5.staticflickr.com/4894/4596...f011_z.jpg]
[Image: https://farm5.staticflickr.com/4804/4668...4345_z.jpg]
I then used push pins to position the pieces to be glued.
[Image: https://farm5.staticflickr.com/4826/4577...83f1_z.jpg]
I let the inner loop set for an hour (this is 5-minute epoxy) - then I glued it to the main dial in the same way:
[Image: https://farm8.staticflickr.com/7886/4668...006e_z.jpg]
I'm happy with how it turned out as the repair seems sturdy and less obvious than the prior repair.
Tonight I reassembled everything.
[Image: https://farm5.staticflickr.com/4888/3175...d195_z.jpg]
Threads: 336
City: lawrenceville nj
nice work Nathan
Threads: 18
City: Cromwell
State, Province, Country: CT
I love how your radio turned out. It’s nice to watch someone take their time and do a top notch job. Nice job on restuffing the caps,just like new only better insides
Fixing the dial is something I’m all too familiar with. My 38-690 dial had a crack on the inner ring and the dial was free spinning when I got it. I super glued mine. Then I found that someone made another notch to situate the dial differently on the assembly instead of repairing the mechanism properly.
The factory notch was chipped so the dial would not stay on the mark. I used a couple of thin strips of a paper material between the dial ring and the drum to hold it in place better. A little more tension was all it took to keep the dial in place.
Tony
Threads: 212
City: Seattle
Thanks Sam! Thanks Tony!
Automatic Tuning Flex Coupling
I've been working on rebuilding the automatic tuning flex coupling.
[Image: https://farm8.staticflickr.com/7839/4584...0bb9_z.jpg]
Here it is removed from the tuner:
[Image: https://farm5.staticflickr.com/4852/4603...0998_z.jpg] [Image: https://farm8.staticflickr.com/7920/3181...59a8_z.jpg] [Image: https://farm5.staticflickr.com/4865/4603...3504_z.jpg]
You can easily see that the old one is stiff and cracked. That makes the tuning mechanism hard to turn unless the RF subchassis and automatic tuning dial are perfectly aligned along their axes. There needs to be some flex in the system in order for the dial to always tune smoothly.
The first stop was to visit the excellent article in the Philco Library's tech section on exactly this topic. It was a great source of ideas and inspiration - but I ran into a few things that prevented me from just doing things exactly the same.
I disassembled the coupling by drilling out the rivets:
[Image: https://farm5.staticflickr.com/4888/3181...8ddb_z.jpg]
The resulting pieces:
[Image: https://farm8.staticflickr.com/7891/4603...6af8_z.jpg]
Hmmm... a few too many pieces actually! The metal parts are made of a pretty brittle material and I broke the thin center piece while I was trying to push out the rivets.
[Image: https://farm5.staticflickr.com/4834/4670...5ed3_z.jpg] [Image: https://farm5.staticflickr.com/4822/3184...de1d_z.jpg] [Image: https://farm8.staticflickr.com/7829/4676...a57c_z.jpg]
In the mean time - ordering the cloth impregnated neoprene sheet. I found a sheet with similar specs from zoro.com - actaully eBay.
[Image: https://farm5.staticflickr.com/4894/3288...1bca_z.jpg]
What I didn't think about too carefully ahead of time was the following:
Quote:After disassembly the next step was to cut new rubber disks from the sheet of material. This was done with a gasket circle cutter and a punch for the rivet holes.
![Icon_problem Icon_problem](https://philcoradio.com/phorum/images/smilies/icon_problem.gif) I don't own either of those tools. Always on the lookout for an excuse to buy a new set of tools I researched it but it looked like nice gasket circle cutter (especially 2" diameter) would set me back some $$$. So I decided instead look around for a similar precut circular gasket. I should've done that first as I found just the thing at my local hardware store!
[Image: https://farm5.staticflickr.com/4816/4586...7743_z.jpg]
While it's not reinforced with cloth like the original it looked robust enough to give it a shot. I went with the 1" ID, 2.25" OD neoprene washer. It's about the same thickness as the original.
I picked up some 5/8" long screw posts (aka Chicago screws) to replaced the long drilled out rivets:
[Image: https://farm8.staticflickr.com/7837/3981...3a3b_z.jpg]
I used one of the old rubber washers as template and drilled holes in the new ones:
[Image: https://farm8.staticflickr.com/7835/3290...544d_z.jpg]
I attached the outer set screws pieces with 3/16" x 3/8" pop rivets:
[Image: https://farm5.staticflickr.com/4901/4678...4a08_z.jpg] [Image: https://farm8.staticflickr.com/7896/3184...51f5_z.jpg]
I used finishing washers as the spacers which keep the two washers apart (part of the original piece that broke).
[Image: https://farm8.staticflickr.com/7862/4586...c89e_z.jpg]
and recreated the middle piece from aluminum stock (~0.060" thick).
[Image: https://farm5.staticflickr.com/4851/4585...0a90_z.jpg] [Image: https://farm8.staticflickr.com/7854/3183...eecb_z.jpg] [Image: https://farm5.staticflickr.com/4848/4678...a5c7_z.jpg]
And all the pieces put together:
[Image: https://farm8.staticflickr.com/7823/4605...09d6_z.jpg] [Image: https://farm5.staticflickr.com/4873/4673...9d11_z.jpg]
And reinstalled:
[Image: https://farm5.staticflickr.com/4808/4673...0fee_z.jpg] [Image: https://farm8.staticflickr.com/7880/3184...8cd8_z.jpg]
It seems like it works quite a bit more smoothly and the tuning mechanism turns easily. We'll see for sure once the dial is reinstalled.
Threads: 269
City: Bandon
State, Province, Country: OR
Excellent!!
Threads: 44
City: Menlo Park
State, Province, Country: CA
It is a pleasure to read and view this excellent work, presented in such great detail.
Hats off to you, Sir!
Threads: 49
City: Allendale, MI
Well, you inspired me to start my 37-116! Decided to start the sub-chassis first and have that finished. Had to disassemble to get to all the caps and check the resistors. I'll start another thread to note the progress.
Cannot Adjust an IF Transformer’s cores
The abilities of our 'Phorum Pholks" never ceases to amaze me! Fantastic fabrication, Joseph! I'm waiting now for...GarySP — 08:27 PM |
PT-6 antenna connections
Thanks. I never realized that was a notch noted in the schematic as described. I’ll recheck my wiring.bridkarl — 08:13 PM |
Thank you! I was quite new to the Phorum when I started this post, so I feel like it might be advantageous to publish a ...jrblasde — 08:07 PM |
Notice in the schematic the notch at the bottom of the antenna coil is between pins 3 & 4.
Yes, pin 6 of the 7C6 is...RodB — 07:34 PM |
bridkarl
I have two PT-6 chassis. On both there is a blue wire that runs from the above chassis transformer to pin 6 of 7C6. So t...bridkarl — 07:23 PM |
Joseph, now you are an engineer!!RodB — 06:37 PM |
Hi, reading your explanation I can see the confusion. If you take it one connection at a time it should result in a desi...RodB — 06:34 PM |
It works! I received the PCBs this morning in the mail, and put everything together. I reused the base from the original...jrblasde — 04:32 PM |
I seem to have lost my way on this PT-6.
I see the antenna aerial transformer schematic - I’m reading pins 1 through ...bridkarl — 12:30 PM |
40-150 General questions
Good thing you're a good electrician ... the pictures show a lot of rewiring in your future! Take care and BE HEALTHY!...GarySP — 11:52 AM |
There are currently 4014 online users. [Complete List] » 3 Member(s) | 4011 Guest(s)
