Philco 42-350 dial pointer
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Just sent the photos. If you think it will work for you, you are welcome to have it. Glad to help.
Gregg
Threads: 7
City: Mason
State, Province, Country: OH
Gregg - I can't tell from the photo does it slide along a flat metal back plate?
Threads: 22
City: Kewanee
Terry I sent a few more pics. It slid across a glass dial. The top tee section where the dial cord runs through it sat on the top edge of the glass dial. The needle is slightly offset from the tee to make up for the thickness of the glass dial.
Gregg
Threads: 22
City: Kewanee
I just sent a pic of it sitting on the glass dial to give you a better idea of how it was.
Gregg
Threads: 7
City: Mason
Just got them.
I don't see any kind of notch or groove that would fit the metal plate I have but it the needle is certainly long enough.
Even if I have to "Frankenstein" into something I can use I think you at least solved the actual needle part of all this.
If you have a chance can you mail it to: Terry Lett 309 Four Seasons Drive Mason OH 45040?
I really appreciate your help on this. I was making such good progress on the rest of the radio until I hit this snag.
Thanks again Gregg!
Threads: 22
City: Kewanee
Absolutely, I'll drop it in the mail tomorrow. Like I said if you can make it work, give it a shot. If you can't, throw it in a drawer like I did.
Gregg
Threads: 7
City: Mason
Threads: 22
City: Kewanee
Terry I mailed the pointer today, so you should have it Tuesday or Wednesday. I hope it works out for you.
Gregg
Threads: 7
City: Mason
I can't thank you enough.
I'm sure I can make it work. The real challenge will probably end up stringing the new assembly.
Dial stringing is like slow torture.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial. The first s...HowardWoodard — 01:01 AM |
Well, finding a short is easy.
Like I said, disconnect the transformer's secondary windings and see if it persists.
If...morzh — 09:48 PM |
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM |
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM |
Rogers Majestic R-646
Kinda weird to see both open
Nothing weird if you remember that this radio is about 100 years old :)Vlad95 — 07:49 PM |
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM |
Thanks Morzh
Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM |
Well...pull out every single load of the transformer. For every winding.
Unsolder if needed.
Then re-do your dim bulb....morzh — 07:02 PM |
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM |
Vlad;
I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM |
There are currently 871 online users. [Complete List] » 1 Member(s) | 870 Guest(s)
