Are these capacitors?
Looking at re-capping a Sparton model 835 chassis and found these odd looking caps under there.
A few have a crusty coating on them as if they were leaking.
A couple shown in the picture don't have the crust, but look like there is a wire winding under the coating.
Are these a different style of cap that Sparton used in 1935, or are they something else?
I am used to having the cap values clearly marked on the paper and wax caps.
Apparently on this radio, you have to chase them down on the schematics.
Anyone have any suggestions here?
murf[Image: https://oi1161.photobucket.com/albums/q5...0483_1.jpg]
? Link isn't working.
I believe they are chokes I had some of them in my sparton 1466.
Ok, but what is the crusty coating on the center one?
Others have tar like covering on them and one has friction tape wrapped around it.
There are several of these critters under this chassis.
Murf
Ah yes, photobucket works sometimes and not other times.
I just clicked on the pic and it did work.
Go Figure.
murf
and ... to the opposite end of the rainbow....
the object i am pointing to here *******IS NOT*********** a capacitor..
which kinda blind sided me because this is the first time i ran into these which are resistors.
Yes. Those are wire-wounds. Used quite a bit, in Philcos, in Zenith TOs. Probably in other places too.
Well, I found after tracing them on the schematics, that the crusty looking one is a capacitor and the smooth looking ones are indeed wire wound resistors.
Re-capped it and its now playing pretty good.
Could use more volume, but it is pretty clear.
murf
My Philco 37-116 Restore
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
