Philco 21
So, here are some pictures.....
I need one small knob
The front is bowed out a little
Here's the underside
will post more of the backside when I get the chance...
If you want to replace any of the cabinet parts like the baseboard or front panel give Steve Davis a holler. Does great work and prices are reasonable. Mine needed a front panel, baseboard, rear arch, and base trim.
Here's some more, of the back; uncleaned as found condition of course...
Wonder what that hole is for on the top arch?
notice that shim (on right side only) holding the chassis up?
the shaft holes in the front are not centered, wondering whats going on!
lots of tree leaves and junk
the 3 tubes left to right are 45, 80, and UX-245
I'd have a look at this instead of the Rider's:  https://philcoradio.com/library/index.ph...-model-21/  It's more accurate and comprehensive.
Congratulations!  Finding a model 21 is almost like winning the lottery.  They had a very short production time, giving way to the 70 and 90 models.  Worthy of restoration regardless of the "found" condition.  Take care, Gary
(04-18-2019, 05:13 PM)Radioroslyn Wrote:  I'd have a look at this instead of the Rider's:  https://philcoradio.com/library/index.ph...-model-21/  It's more accurate and comprehensive.
thanks, I will!  haven't fully explored this site yet!
(04-19-2019, 11:50 AM)GarySP Wrote:  Congratulations!  Finding a model 21 is almost like winning the lottery.  They had a very short production time, giving way to the 70 and 90 models.  Worthy of restoration regardless of the "found" condition.  Take care, Gary
Yes!  you know what they say; even a blind squirrel....finds a nut once in a while!  I intend to restore carefully, and not overdo it...my son will do the cabinet work, and I will stumble through the electrics....
The 21 is more or less the 20 that looks like the 70.
More so, the early run used the 20 chassis.
So most of its value is in is rarity rather than the performance or the looks.
I wouldn't mind having one to enhance the early Philco models line I have. But I know exactly how it's going to sound. Icon_smile Cause I got the rest of them.
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
There are currently 1233 online users. [Complete List]
» 1 Member(s) | 1232 Guest(s)
