47-1227 - Radio will not tune in any stations.
Threads: 3
City: Middletown, PA
State, Province, Country: Pa
I have a Philco model 47-1227. It has been completely restored. All capacitors and resistors have been replaced. The audio works. We get sound from the record player but unable to tune in any stations. Have minis 2.5 volts at osc. tube. osc. tube does not change voltage when tuning dial is changed. No am or fm. Any ideal what's wrong? HELP!!!!!!!!?!
(This post was last modified: 06-09-2019, 06:53 PM by Lucky.)
Threads: 268
Time to break out the signal generator and inject a modulated 455kc signal @ test point A. This is w/the set set up to receive an AM signal and see what you get from the spkr.
Threads: 3
Receive nothing from test point A or when connected to antenna
Threads: 268
Ok inject a 455kc signal @ pin 1 of the 6ba6 and see what you get from the spkr.
Threads: 3
We get nothing from pin 1
Threads: 268
How about pin 6 on the 7R7.
Threads: 3
Pin 6 works with. Get loud tone
Threads: 3
06-09-2019, 08:38 PM
Pin 6 works. Hey loud tone.
(This post was last modified: 06-09-2019, 08:39 PM by Lucky.)
Threads: 268
Ok so you have a problem around the 6BA6. Check the pin voltages according t o the service info. Also be sure the heater is lit.
(This post was last modified: 06-09-2019, 08:46 PM by Radioroslyn.)
Threads: 3
pin 1. -.26 volts
pin 2. 0 volts
pin 3. 0 volts
pin 4. 0 volts
pin 5. 280 volts
pin 6. -1.14 volts
pin 7. .06 volts
Heater is lit
(This post was last modified: 06-09-2019, 09:09 PM by Lucky.)
Threads: 43
City: Brownsville 42210
State, Province, Country: Kentucky
filament should be pin 3 & 4 and pin 6 should be 100v
(This post was last modified: 06-09-2019, 09:48 PM by jake wells.
Edit Reason: error
Threads: 3
pin 3 grounded at center of tube
pin 4 shows 6.6 volts ac
The tube is lit and working
Threads: 43
pin 6 should not be reading -1.14 it should be 100V check the resistors and capacitors in that circuit.
Threads: 3
Will check Tomorrow night.
Threads: 43
Tim,
nice write up and thanks for sharing !!
Sincerely Richardradiorich — 02:47 AM |
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM |
Shadow Meter Bulb
Phorum members, I am trying to find the bulb # for PHILCO Shadow Meter part number 45-2180 that is from a 37-640 chassis...georgetownjohn — 06:53 PM |
Philco 41-608 changer coupler
3D-printing...short of machining, of course.
Or molding.morzh — 05:20 PM |
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal piec...alangard — 05:07 PM |
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM |
12' Philco
Rod,
Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently.
H...morzh — 12:54 PM |
