Threads: 7
City: Austin
State, Province, Country: Minnesota
I read on a resource website that I can change all my paper/wax capacitors to film capacitors of a higher volt rating.. Did I understand that right? And can I find the one with the highest VDC and switch them all out to film capacitors of a equal VDC or higher? I think I am finally beginning to understand this. I’ve got a learning disability so it takes me longer to understand stuff (especially when written and on here. I’m more of a visual learner so, please be patient with me guys. I’ll probably be asking some more questions
Adam
Threads: 70
City: Linn Creek, MO
Adam, I am also one that learns by doing.
You can use 630 volt film capacitors to replace all the paper capacitors in your radio. There may be an exception on some radios such as a cap connected to the primary of the output transformer. You can use the “orange dip “ type or the yellow tubular ones, it doesn’t make any difference at all. There are several dealers selling capacitors, including a couple of members of the Phorum
M R Radios C M Tubes
Threads: 7
City: Austin
Thank you Steve! That makes it a lot easier to restore this thing, hopefully I can get this playing again soon. A few of the paper capacitors look blown to me anyway but, I’ve read not to bother with them regardless and just replace them. The speaker maybe bad too but, I won’t know that until I’ve recapped everything
Threads: 7
City: Austin
Steve, do I need to get them all in the different Ufs that the schematic calls for or can I just use the highest one it calls for to cover all the ranges?
Threads: 270
City: Wilsonville
State, Province, Country: OR
Adam, you should get the film capacitors with capacitance (uF) values close to the values that are in the radio or on the schematic. Modern capacitors do not come in some of the odd values that used to be used but you can usually get something close. Close is usually good enough.
Threads: 70
Yes, an example .05 is no longer a standard value, in this case you would use .047 or if your radio has a .02 you would use a .022. As Bob said close will be good enough.
(This post was last modified: 06-23-2019, 08:29 AM by Steve Davis.)
Threads: 7
City: Austin
Thanks for the help guys!
Threads: 7
City: Austin
Steve, my schematic saids one is .01uf.. Would I use a .22uf in that case too? I’m assuming I would
Threads: 7
City: Austin
No, use a new .01 uF.
This might help:
If the schematic reads - Use
.001 uF - .001 uF
.002 uF - .0022 uF
.003 uF - .0033 uF
.005 uF - .0047 uF
.01 uF - .01 uF
.02 uF - .022 uF
.025 uF - .022 uF
.03 uF - .033 uF
.05 uF - .047 uF
0.1 uF - 0.1 uF
0.2 uF - 0.22 uF
0.25 uF - 0.22 uF
0.3 uF - 0.33 uF
0.5 uF - 0.47 uF
Threads: 553
City: Jackson, NJ
0.07uF - 0.068uF.
Threads: 7
City: Austin
Tim,
nice write up and thanks for sharing !!
Sincerely Richardradiorich — 02:47 AM |
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM |
Shadow Meter Bulb
Phorum members, I am trying to find the bulb # for PHILCO Shadow Meter part number 45-2180 that is from a 37-640 chassis...georgetownjohn — 06:53 PM |
Philco 41-608 changer coupler
3D-printing...short of machining, of course.
Or molding.morzh — 05:20 PM |
Thanks, Morzh.
That solves the issue of the rubber pieces. Now, I need to find a way to replicate the pot metal piec...alangard — 05:07 PM |
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM |
12' Philco
Rod,
Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently.
H...morzh — 12:54 PM |
There are currently 6941 online users. [Complete List] » 1 Member(s) | 6940 Guest(s)
