AM AND FM RADIO RECEPTION
I have 3 old vintage radios, and am having a similar problem with all 3. The 2 with AM radio bands will get a strong station signal and I will be listening to the station, and then suddenly the radio will just lose the station. And, when I try to adjust the dial and get it back, no luck. Also, the one slightly newer radio that has a FM band has the same problem. When I turn it on I can hear 1 station kind of in the background with a lot of other stations (noise) in the background as well. When I adjust the dial I can still hear all these other stations until I get 1 strong station. Then after I listen for a while, the strong station will fade out and I am back to noise. I have tried multiple different antennae on all 3 units with no better results.
Is this an antenna problem, or could it be a tube, the tuning condenser....or what? Help...Thanks, Sonny
Have the paper and electrolytic capacitors been replaced in these radios?
No, they have not. Do you think that is the problem? Thanks.
Most likely.
Those old capacitors are now 50 or more years old, and are long past their useful life expectancy.
http://www.philcoradio.com/tech/plugin.htm
http://www.antiqueradio.org/powerup.htm
Thanks Ron.
Thanks Morzh. So it appears I did wire it incorrectly and I have to switch the wires between pins 2 and 4.bobclausen — 11:36 AM
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
There are currently 1156 online users. [Complete List]
» 1 Member(s) | 1155 Guest(s)
