Help identifying cartridge/needle
I recently found a Zenith record player with a VM changer, but I think the cart is bad. I have looked up on the VM website, and have the Sams on both the unit and changer (generic) but cannot find a good match. It is a needle/cartridge unit that plugs in. I have some pics. It is NOT a 993-ds13 (95D), tried one which looked the same in the pictures, but wont fit. Hope someone can help (Kirk  Icon_wink ) Model is HFY12R
It looks like a 940 or 943 is possible, but I cannot really tell from the pictures provided.
Tim
I believe that's one of those "power point" type cartridges....  Astatic 89 T.  NOT a real good cart for taking care of your records though.
I looked up the 89T, but it is more square, so I dont think this is the correct one either. Thanks for the input tho. I got a 993 off Ebay, looked like it in the picture, but it is just a little different and wont plug in.
Tim
Yea, I sorta thought there was something odd about that flipover tab, from the 89T.
The VM I had (that was identical to yours), had a Sonotone 2TA in it, . . . a VERY good mono cartridge, as ceramic cartridges go.
If you can't get your exact replacement,  I would consider a 2TA or it's Astatic replacement 751.
If you would rather consider converting it for stereo, the Sonotone 8TA is also an excellent stereo ceramic cartridge.
Thank you Jake. I may try that in my 557. I got a response from VM and they said it was a 940, so for now, I know which one to try. I am restoring another changer that may use the cart that you mentioned. Got to get the rubber motor mounts ordered. I have about 3 of these I need to get running.
Tim
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM
Tim - Photos of 8 octal tube sockets. (Top and bottom) Send me a PM if you're interested.RodB — 04:11 PM
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM
There are currently 752 online users. [Complete List]
» 1 Member(s) | 751 Guest(s)
