Model 48-460 Code 122
I have a acquired a beautiful 48-460 which I am about to restore. I have pulled a copy of the data off of Riders but it is a 48-460 Code 121 and my radio is a Code 122. I have heard they are similar but this is not. For instance there is no antenna coil on this Code 122, which a 121 has, and there were 4 leads from the internal antenna being used on this model. Also the electrolytic values were not exactly the same. Does someone have a schematic of the Code 122 model that I could have or purchase
Try Chuck Schwark here on the forum.
I have one of these sets and I have the original service bulletin.
Also, production changes notes to cover all Code versions.
You can order a photocopy set thru my website - Schematic Info page.
HNY,
Chuck
Rogers Majestic R-646
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
Philco 89 Code 123 Osc Coil
There are currently 1137 online users. [Complete List]
» 2 Member(s) | 1135 Guest(s)
