Philco 620 voltage readings
I am stalled on a 620. Does anyone have the voltage readings for pins on this model. I am new at this. I am not sure if I have proper voltages. Cathode voltages, plate etc.  Any help appreciated. Joe
Schematic info including voltages at: http://www.nostalgiaair.org/pagesbymodel...013804.pdf
and a clearer version of the schematic is here: https://philcoradio.com/library/download...l.%201.pdf
Thanks, I will check it out. Joe
Hi Joe and welcome,
I'll add a few notes to the voltage readings. They may be somewhat higher (10-20%) as the higher line voltages and the meters used in those days had a low input resistance which would tend to cause a drop in the voltage being measured. Now days meters are 1Meg or much higher.
Should see abt -20dc on pin 5 of the 42 and a couple of -volts on the cap of the 75.
Don't think having the volume control full up is necessary. Shouldn't change the voltage reading just makes servicing more annoying.
I'm assuming that you've replaced the caps, if not do so unless you like chasing your tail!
Changed caps, also check tubes and start the radio without any tubes in, only check power transformer.
And when tubes are in, make sure the speaker is good and plugged in before the power up.
Thanks for the help. I think I am going to enjoy visiting this site.
Oh I am sure you will. It's addictive. And there is no Naloxone for it. Icon_lol
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 678 online users. [Complete List]
» 1 Member(s) | 677 Guest(s)
