Need Help With ID and Schematic
Hi - New member here . . . I recently picked up a Philco integrated mono amp that was supposedly pulled from a record player. It's PP 6L6 with a pair of 12AX7s and a 5U4. The only number on the chassis is 7004298650. I did a search at the Sams site but got nothing. Does anyone here know what model this came from or have a schematic they could share?
Here's a link to a pic in case my attempt at attaching one doesn't work: http://www.flickr.com/photos/11175168@N02/5366251655/
Any help or info would be greatly appreciated!
Thanks . . . Charlie
Charlie,
Might be an E-1776:
http://www.radiomuseum.org/r/philco_e_1776.html
Carl
Northern Panhandle, WV
Thanks Carl! I haven't downloaded the schematic yet, but that certainly looks like the amp.
. . . Charlie
Rogers Majestic R-646
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1030 online users. [Complete List]
» 1 Member(s) | 1029 Guest(s)
