no stations on a 40-215
can't find stations on am or shortwave ,i get a lot of static out of speaker.i have an eico signal generator but how can i be sure it is putting out a signal? i follow the paper work on setting the radio and generator but get nothing .need help.thanks
So what have you done to the set so far??
Check the antenna and oscillator and if coils for open windings.
replaced all capacitors,some resisters,and checked all tubes which are ok.filament voltages check out ok at 6.3 volts.plate voltages look good.
As for the Eico use a well calibrated receiver to check to hear if it is working and it's dial calibration. Once that is verified inject 400cy at 470kc signal into the ant post and adjust the 1st and 2nd IF transformers for maximum modulated tone from the spkr.
ok i'll check that out.
i found the problem ,there was a wire missing from the 78 if tube to the 6j8 tube .i kept following the schematic for the 40-215 and looking at others with a mystery control and there it was .that schematic for this radio is blurry and the dots that show connections are not present or not in the right place.once that wire was in place i turned it on and we had music. Icon_clap now i can tune everything in .thanks for the help. Icon_biggrin
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
There are currently 1286 online users. [Complete List]
» 1 Member(s) | 1285 Guest(s)
