I may have goofed...
Chuck, and all, If I were to replace, say, a .05mfd capacitor, with perhaps a .0047 rather than a .047, such as at locations 6, 13, and 15 in my Ant. and RF sections of the subchassis, would they work for a bit, then give me the problems I am experiencing?
Seems I may have done just that... I appear to have added an extra "0" to the numbers I needed for these condensors, and so have been operating with the wrong values. I just pulled the RF subchassis apart to check switches and coils per Chuck's suggestions, and noticed the new pieces I picked up(which have correct numbers) as spares, in case I needed to replace them this time, were a good deal larger than what I already had put in there: thus I went back and checked my original notes, and discovered my error...
I just went back to my notes, and bills for parts, and confirmed my error...
Never write stuff when tired!
I will be waiting for confirmation of my theories here...
Thanks
Scott(who feels stupid. er)
Well, anyway, I am learning LOTS of GOOD LESSONS for next time!
Arrrggghhhhh!!!
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
Most probably. Cap 15 is the RF tube plate bypass cap on the B+ line.
Caps 6 and 13 are on the AVC buss. Cap 6 is for bypassing and cap 13 is the time-constant/filter cap in conjunction with resistor 34.
They "filter" out the audio freqs on the AVC buss which is only the DC component of the deteced signal. Too little filtering (or too short a time-constant) lets the AVC buss "bobble" up and down in time to the audio causing wild gain shifts making the detected signal jumpy which again makes the AVC buss even more jumpy, etc....
Thanks, Chuck! Think anything else down the line might have been damaged that I should look for? I was planning to replace the resistors and the two mica caps in the RF subchassis(which have already been replaced once) but if the 6,13, and 15 caps are the issue, I might not- unless you think there may be good reason to...
Thanks!
Scott
Always fix one problem at a time.
If those parts are already changed once, leave 'em alone. Just be sure they are the correct values too.
Those three bypass caps being only one-tenth the size they need to be is probably 95% of leftover problems you have right now.
Chuck- I went through and looked over all the values obtained... I am certainly learning from my mistakes...
Always "read" resistor codes when received
Always double check values to be ordered twice before ordering, and again when received.
Don't get your bare arm too close to a nicely warmed tube.(That one didn't need much discussion...)
Keep pointy tools, such as solder picks, away from where they might puncture speakers. Alternately, keep speakers from where they might get punctured, or make a cardboard protector plate.
I'm still populating the list, but the next radio should go smoother!(I have to recap a simple Motorola for my best friend- payment for the 46-1203 he gave me...) Then I have to decide which radio to tackle next, while I listen to the 37-650 playing...
Scott
Welcome to The Explative Deleted Club.
We've all been there at one time or another... Icon_smile
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
