Mystery AVC issue on 38-9
Threads: 6
City: Severance
State, Province, Country: Co
Hello all. I can use some help on another mystery problem, this time on a Philco 38-9
http://www.nostalgiaair.org/Resources/262/M0013262.htm
This is a customer radio that will drop the volume after about 10 min playing. Low to moderately strong stations drop out completely, while stronger stations are still at a listenable level, although equally diminished.
Measuring the AVC voltage tuned to a moderately strong station, at the junction of resistor 15 and cap 3, I see that the voltage starts at about -5 VDC then slowly rises to about -.5 VDC, where the radio abruptly loses volume. Turn is off and let if cool, for a few minutes and and cycle repeats.
I have replace all Electrolytics (twice), all other caps (including the two micas ) and most resistors including 43
I have swapped tubes multiple times
The power transformer voltages are stable
The voltages on all tubes are within tolerances
I have spent hours and hours on this one. I would appreciate any suggestions where I might look as to the source of the disappearing AVC voltage.
Thanks Steve
Threads: 114
City: Sneedville, TN
You haven't said whether you have replaced the paper condensers, I would start there. I suspect the problem is in #23, or #19a, 19b, or 19c. You also may have a resistor which is changing in value as it heats up, especially #20 or #21. It could also be #28, #31, #34, or #36. First step is to replace ALL the paper condensers if you haven't already. If one is sliding in value as it heats up, it means that ALL of them are not reliable any more. I always replace ALL the paper condensers as well as the electrolytics before I do anything else, even before I turn on a set of this age.
Threads: 70
City: Linn Creek, MO
The AVC voltage is not the problem, it is a response to the problem. Something in the front end or the IF is causing the signal to drop, the AVC is trying to compensate. You might try a can of circuit cooler to locate the problem.
M R Radios C M Tubes
Threads: 6
City: Severance
Yes, all the paper capacitors have been replaced. Steve
Threads: 6
City: Severance
Thanks Steve, I totally agree. I need to find root cause. I'm not familiar with circuit cooler or how it's used. Can you fill me in.
Threads: 20
City: Greenville, TX
Here is a source:
https://www.govets.com/maintenance-repai...VNEALw_wcB
Do not keep it on one component very long. Quick spray is enough.
Threads: 6
City: Severance
Good stuff. Have you ever tried cooling the major components: transformers, variable caps, tubes, etc ?
Threads: 553
City: Jackson, NJ
Canned air (duster) when the can is inverted act as a cooler.
Threads: 6
City: Severance
It was the 6K7G. As you all know, Philco radios, with the heat shield socket in tact it will only allow 6K7Gs. 6K7s or 6k7GTs wont fit, at least not without some encouragement from Mr. vice grips. I had 3, count 'em, 3 6K7G's test ok, but all would result the exact same symptoms in the radio. Out of desperation i ground off the rivets holding the socket and shield and put in a metal 6K7, ..... Bingo.
Thanks to all for the help. There are alot of great ideas here I can use next time. And one thing is for sure, there will always be a next time.
Tim
Well...a chassis is metal. Magnetic or not, it does not matter.
A transformer has some hum to it. It is natural....morzh — 08:40 PM |
Shadow Meter Bulb
Ross
I am not sure what current limiting effect the incandescent provides.
They are two different parts of the sch...morzh — 08:31 PM |
12' Philco
Bob
Thanks for that photo.
I have been looking for it, and I cannot find anythinmg on the web.
I forgot it was here...morzh — 08:29 PM |
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55.
I ...georgetownjohn — 07:31 PM |
12' Philco
There was also this Philco!
klondike98 — 07:25 PM |
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM |
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM |
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo
This is something alright. I'm go...RodB — 06:26 PM |
:lol: We need to start a singing radio group! I play the guitar, so maybe get a few vocals? Anyways, Mike, I did try mou...TV MAN — 05:56 PM |
And so does a barber shop quartet. mmmmmmRodB — 03:54 PM |
There are currently 6616 online users. [Complete List] » 2 Member(s) | 6614 Guest(s)
