Philco 37-670 Question about candohm resistors
Hi Everyone!
I have recently finished re-capping a Philco 37-670 and I’ve replaced all out of whack resistors. The only thing left to do is to replace the two candohm resistors. My question is what wattage should the new resistors be? I have 5 watt resistors on hand, but should I go up to 10 watts?  Or more?
Thanks for your help!!!!
-Jason
Hi Jason - Are your candohm resistors open? Just curious since it sounds like you've done the recap. I generally leave them if they're working.
I used 25W resistors on my 37-2670 (very similar set). They still get pretty warm so be sure to mount them to the chassis - or in my case I used an aluminum sheet to mount them so that I didn't have to drill additional holes in the chassis. I use lithium grease under them to ensure decent heat conduction.
[Image: https://live.staticflickr.com/65535/4966...39c4_c.jpg]
To add, if Candohms aren't open, being wirewound type their value doesn't go far from original.
I keep them unless 1) open, or 2) leaking to the shell (popular failure mode in Zenith TO 7G605) which causes hum and is overall unsafe.
Hi guys!
Thanks for your replies, they’re very helpful! The resistors are still good - their values are pretty dang close to what they should be. I was just afraid to leave them in as I’ve heard that they can short and I’m afraid of blowing up the power transformer. But maybe I’ll go ahead and leave them. I have another Philco model and I left the candohms in that one and it works fine.
Thanks again!
-Jason
Here’s a picture of it all re-capped.
Edit: For some reason the picture won’t show up   Icon_wtf
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
:lol: We need to start a singing radio group! I play the guitar, so maybe get a few vocals? Anyways, Mike, I did try mou...TV MAN — 05:56 PM
And so does a barber shop quartet. mmmmmmRodB — 03:54 PM
There are currently 6631 online users. [Complete List]
» 1 Member(s) | 6630 Guest(s)
