An RCA 140
Ah, the beloved coil rack. Here's the 'other' side. Those caps had been replaced at least once already. The rubber stamps from the repair shop in the earlier photo were underneath the rack.
[attachment=0]
Well, my 140 is now sitting silent at home. The cost to repair it right now is a bit high and still no luck on finding an input transformer for it. So, I think I will let it sit until next spring when I will feel like messing with it again.
Doug Houston Wrote:...The 53 became 6A6 (both fat pin), then 6N7G (octal)...
Is there any list of such tube history? I remember that somebody wrote that the 78 was superior to the 6D6 and a direct replacement, and some history on the tubes.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
If I recall right, my radio buddy and paid repairman has said that the 78 and 6D6 are indeed interchangable. Not sure if one is better than the other or not. I think the 6D6 is just a more 'modern' replacement that happened in the time right before octals came into being. Now I am curious as well. Icon_confused
I might have this totally backwards but...78 is the older of the two but is preferred by some. Has to do with the internal shielding construction. Apparently the 6D6 is a bit more prone to self-oscillation in some circuits.
I tried using a 6D6 as a replacement for a 78 as an IF amplifier in a Philco once, and it didn't work. I don't remember which Philco model it was.
After that, I stocked up on 78 tubes.
YMMV.
I know this is an old subject, but WOW, NICE job on the cabinet!!!! I have an R 7a upstairs in my "someday I'll get to it" radio place. After looking at your nice work am now thinking about moving it up in the priority of things to restore next.
Well OK, but the output transformer is also a big offender. The whole set was so crammed into that chassis, that it appears that the output transformer was somewhat inadequate, especially sincw the operating conditions of the 53 were such that it could belch out 10 watts. In those few years, RCA was riding high, with their high power audio, but it was mostly, if not all, class B. If you opened the volume up all the way, you'd get lots of sound, but it was lousy (class B) sound.
The interstage transformer is a DRIVER transformer, so you'll notice on the schematic that the secondary DC resistance is lower than the primary resistance. The 56 is pushing a class B amplifier, and the grids do draw current.
Hello.Was wondering if anyone has a 14o parts chassis?I have one of these and it is missing the tone control reactor(l35)..Tryed using a resistor in place of it but the radio breaks down at anything above 1/3 volume.
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
