Model 70 Chassis Swap?
Are the innards of this 70 Lowboy (High?)the same as in the cathedral? If so I may be able to complete my table set.
The chassis looks the same in the vague photo.
[Image: http://i150.photobucket.com/albums/s92/u...1515f9.jpg] [Image: http://i150.photobucket.com/albums/s92/u...57134c.jpg]
[Image: http://i150.photobucket.com/albums/s92/u...391730.jpg]
Yes, the 70 console chassis is the same as that used in the cathedral. In this case, the speaker is the same also, so you could transfer the whole thing to a 70 cathedral cabinet.
Thanks Ron. I hope the seller takes my offer and doesn't think it's a $500 treasure like most of the consoles I've seen
offered around here lately.
Wow! Chassis is in nice shape and still has the original copper electrolytic caps!
Just wondering if you got it? n
tractorforum.com *** I reserve the right to be wrong
Yes, I picked it up from the original owners son. The chassis and speaker look in decent shape. I won't feel guilty tossing the cabinet
as something bashed in the middle of the face about 10" across. My cathedral cabinet isn't perfect either but looks easier to get looking
decent. Who knows when I will get around to it though. So many projects to choose from and so little talent to apply.
Could always put the cabinet on Craigslist. Someone around here will buy it and turn it into a cat condo or something if nothing else... Icon_lol
Brian Mattson
Coon Rapids, MN
I will definitely list that and a whole tubless lowboy here first for free and then CL and
"that other place." Probably in spring.
Phil, you say you have a tubeless 70 lowboy? Does it look like this?
http://www.philcoradio.com/gallery/1931b.htm#f
I've been wanting a good photograph of that model for a long time now...
I guess mine is the highboy Ron, it has the bracing between the legs. I assume the difference is in the height. Otherwise they look almost the
same to me. Higher quality veneer maybe? Odd that the more expensive one would be the more common.
The tubeless with chassis/speaker is a different console. I'm using the chassis/speaker of this one for my spare cathedral 70 cabinet.
What model is the tubeless one? I have a Model 90 I'm working on now that I could always use parts for...
Edit: Model 90 Lowboy that is.
Brian Mattson
Coon Rapids, MN
The other is a model 77. I will offer it complete (less tubes) when the winter passes.
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
Peter; The Philco (3)16X was likely a Canadian market Philco, which means that Philco Products of Canada LTD likely h...Arran — 07:45 PM
It is kinda impossible for the plate to have 120V with the tube in and have it not with the tube out, short of the tube ...morzh — 07:42 PM
In case anyone else run into the issue I had figuring out Richey caps I received a response from just radios, and the ne...osanders0311 — 05:07 PM
About all I've done is unplugged them to take the chassis to my workbench. Anything I should check with them?sq65 — 04:13 PM
Have you touched the speaker wires, either speaker plug or the socket?morzh — 03:47 PM
Jonnym
Thanks everyone, I will pull the chassis out of the cabinet and do some checking.    The volume adjustment is not “scra...Jonnym — 02:01 PM
Model 96 volume control
Welcome to the Phorum! :wave: ...and in addition to the annotated schematic that Mike linked to there is the fact...klondike98 — 01:27 PM
There are currently 1563 online users. [Complete List]
» 2 Member(s) | 1561 Guest(s)
