Philco Vol Ctr
I took this volume control out of a Stewart Warner radio it was the wrong control for that radio.
Philco 45-5027, 500M-A, 304723.. Has four terminals on the volume control and has ON/OFF switch.
Could not find info on this, what model Philco would this have come from.
Thank you, please stay safe.
Jim
Spring Lake MI
It may or may not have a direct Philco application as 500k is a very common value and it may have been made for a general replacement part. The fourth terminal is for part of a tone compensation circuit which boosts bass @ low volume levels.
Thank you
Jim
Spring Lake MI
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
There are currently 6032 online users. [Complete List]
» 3 Member(s) | 6029 Guest(s)
