Replacing 41-280 dial lamp wiring
The 3 dreaded rubber insulated dial lamp wires on the right side of the glass dial have to be replaced on this 41-280 chassis I'm working on. Always before, when I've had to replace dial lamp wiring, I just went to my "junque" box and grabbed one that I had salvaged from old chassis. But this chassis has the bulb socket clips that have to be oriented a certain direction to fit on the prong they rest on so they illuminate the dial glass properly. I have nothing in my "j" box that replaces them. All this means I have to remove the bulb socket from the old wire and install new wire directly to the bulb socket.
Can I assume it's a matter of heating the inside bulb contact in the socket so it melts the solder around the old wire and then sticking new solder in there and inserting the replacement wire while the solder is liquid?
Your experience/thoughts?
Art
Art,
Go to Ron's Tech Section and click on Rebuilding Philco Pilot Lamp Assemblies. A nice little tutorial. It works great as I did it for the identical type pilot lite assemblies you are describing on my 41-295.
John
Here's the link:
http://www.philcoradio.com/tech/lamps.htm
Thanks for re-posting that link, Ron; I knew that was going to be a challenge that I will be facing on my 40-190. Icon_rolleyes
All through with that dial lamp wire replacement chore. Cleaning of a "tar" chassis took me 2 days with Mr. GoJo. Rusty speaker housing also responded well to Mr. G. Now on to the underside which I can handle without making my fingers brown. Boy, what a CROWDED chassis!! Icon_eek
Art,
Can't wait to see it when your done. Keep going...
Glenn
Happily back in Illinois..not.
Here it was:
[Image: http://antiqueradios.com/gallery/d/13570...sistop.JPG]
Here it is now:
[Image: http://antiqueradios.com/gallery/d/13570...sisTop.JPG]
(Dial string was installed after this pic was taken.)
All bands and pushbuttons are working. I still need a dial pointer and chassis bolts.
Art,
Do you still need me to look for the pointer?
Glenn
glennpr Wrote:Art,
Glenn
Yes, I do please. I have some others I scavenged off of radios in the past but I cannot make them fit. Hope you find one you can send me!!! Icon_razz
Art
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 745 online users. [Complete List]
» 1 Member(s) | 744 Guest(s)
