Help to repair the Philco Mystery control spring
Hi.
I am restoring my Philco 39-116, and the Mystery control.
In my Mystery control, the dial does not return, because the spring is broken and I only have a little bit.
Does anyone know its length and how it fits inside the pulley, as I only see a small 1mm hole.
See the pictures.
Many thanks.
Regards,
Carlos
Regards from Portugal,
Carlos
Chuck’s Philco Repair Bench has some detailed info on the mystery control. Don’t know if it discusses the spring or not. https://www.philcorepairbench.com/philco...y-control/
Hi.
Thanks Bob for the link.
I found a spring in ebay and now the _Mystery control work perfect  Icon_biggrin
[Image: https://i.imgur.com/HctQor2.jpg]
[Image: https://i.imgur.com/xRowf4Y.jpg]
The video    https://youtu.be/c10beZEvYr0
Many thanks
Carlos
Carlos
New Philco Repair Bench
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
