TH-3 bad power transformer
Hello
I have a Transitone TH-3. The power transformer has a shorted high voltage secondary winding. The Philco part # is 32-7979M. Is this something I could try and repair. If not is there a replacement that someone may have for purchase or a universal transformer that would work.
Thanks
Troy
The rubber insulation used on the leads of this power transformer contributed to its demise, no doubt. I've seen many 1939 Philco models that had rubber insulation on the power transformer leads; with evidence that the rubber melted, then dried out, then flaked off, causing the wires to short together.
I would go ahead and replace it. The original specifications are:
High voltage secondary: 410 volts center-tapped (205-0-205 V), 42 mA.
Filament: 6.3 V, 2A.
You'll need a vertical mounting transformer, which is easier to find than a horizontal mounting transformer.
Either a Hammond HX-269EX or HX-269GX will serve as a replacement. I think I would go with the HX-269EX; its high voltage secondary is 380 volts center-tapped (CT), compared to the 450 volt CT output of the 269GX. Too much B+ could upset the circuitry of the TH-3; causing squealing/oscillations, etc.
You can buy Hammond transformers from Radio Daze.
http://www.radiodaze.com/
I have a Transformer, I bought a chassie for a antenna coil , it has a power transformer , contact me ,BILL
Table radio 51C or 52C?
I suggest you take that look under the hood eventually. Makes little sense to try to figure things out without looking ...morzh — 07:03 PM
Unidentified Philco Bakelite
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM
Morzh There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM
Looks like a Tropic of some sort.morzh — 04:26 PM
The knobs I would guess are not original. PaulPaul Philco322 — 04:14 PM
This unit just became available on a local Canadian marketplace. The seller is unable to find a model number on the back...jrmott2 — 04:03 PM
Ok guys I've corrected the polarity of the area that popped the capacitor and resistor. I do have a question in regard t...osanders0311 — 04:02 PM
I would love to see the underside of that set, good luck and when you get that all cleaned up and running you will have ...Paul Philco322 — 03:17 PM
>>> Curious how this thing is getting 5V and 2.5V. Not sure I understood. There is that power transformer, it...morzh — 03:12 PM
I have noticed that Marconi cabinets, from that era, didn't really go overboard with the shading lacquer, at least on th...Arran — 02:16 PM
There are currently 756 online users. [Complete List]
» 1 Member(s) | 755 Guest(s)
