Philco Model 49-1602
[attachment=22841][attachment=22841]         New to the PHILCO Phorum so if I do something incorrectly pleas let me know. Just inherited a Model 49-1602 and trying to determine a value.  Radio works well and the 78RPM player works mechanically but no sound.  Any help is appreciated.
Hi Rick,
Locate the two wires on the back of the tone arm cartridge with your finger or a screw driver touch
Where there connected if you get a hum that will tell you the cartridge is bad.
Forrest.
Hi Forrest
I will give it a try. Thank you.
Hi Rick, welcome to the Phorum. Your record player originally came with the P30 crystal cartridge which has probably dried out by now and won't produce any signal. If you need to replace it you can find a ceramic cartridge kit at thevoiceofmusic.com for $32. https://www.thevoiceofmusic.com/catalog/...es=Crystal
I put one in a RCA phonograph and it works fine. More advice: Try to avoid powering up the radio until you have replaced the old capacitors, waxed paper and electrolytic. If you don't replace them you risk damaging parts that are difficult to find or replace. Guidance to do this can be found elsewhere on this site. GL with the inheritance.
Rod
Hi Rick,
Rob is rite probably bad cartridge, if you have hum with radio on and volume turned all the way down you have bad electrolytic filters you will have to replace them.
Forrest.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
