HELP for identifying
Hi,
Need help for identifying this model, probably PHILCO, may be model 51 538 (1951) but clock is missing. Stamped on chassis : model 50 52 5121
Is it correct ?
Thanks for interest and replies,
megawave,
French collector
Icon_smile
[Image: http://img222.imageshack.us/img222/1449/chassis2.jpg]
Uploaded with ImageShack.us
It's right there in the photo, black ink-stamped on the rear apron of the chassis.
MODEL 50-52? CODE 121 Last digit obscured. A 1950 model.
Could be a 50-520, 522, 524, 526, or 527.
Chuck
Hi Chuck, thank you for reply.
Photo better below, I can read Model 50-527. Is it Correct ?
Thanks for interest and reply.
Sincerely,
megawave
[Image: http://img64.imageshack.us/img64/1933/philco50527.jpg]
Yep, 50-527, Code 121.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1089 online users. [Complete List]
» 3 Member(s) | 1086 Guest(s)
