Anyone install a cooling fan in these radios?
    The radio chasisis and surrounding area inside my 53-1750 get VERY warm - this is from a combination of a 10W resistor  and the tubes - has anyone ever installed a cooling fan to keep the components and the general insides of the radio cooler??  I'm thinking it couldn't hurt??  Thnx
These radios were made to work at these temperatures. I am not sure they really require cooling.
And the wattage dissipated by your resistor: if it is the same resistance that whatever you replaced it with had before, it then dissipated the same exact amount of power, and the temperature would be the same.
There are currently 2012 online users. [Complete List]
» 2 Member(s) | 2010 Guest(s)
