Anyone see what's wrong with this aircap?
Philco 70. Zoom in.
At first glance, a problem is not obvious to me! (Other than the warped dial. But that's not really the air cap.) Give me a clue!
Not necessarily the cap itself, the unit as a whole and of what it contains.
Hmmm. It looks like a lot of "staining", perhaps because of mouse urine, but that is pretty typical!
The leftmost trimmer cap has most of the top plate missing....if this is it.
Well, I may be wrong, but page 16 of the 1937 Philco List Parts catalog on this site says the bulb bead should be white, indicating a 2.5 volt bulb, not a blue 6.8 volt bulb. The bulb voltage is taken right off the heater 2.5 ac line; I always thought it looked dimmer than it should be - and tried cleaning the socket to no avail.
Then your thread name is a bit misleading as the bulb is not a part of the cap. It jis mounted on the dial assembly which is then attached to it, but the cap ends where there is no longer stator, rotor, trimmer or the shaft.
There is then nothing really wrong with the cap.
The bulb...???
The air cap not on the radio chassis?!  Icon_eek Icon_lol Icon_twisted
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1163 online users. [Complete List]
» 1 Member(s) | 1162 Guest(s)
