Philco Q-1710?
Hi there,
Recently purchased a Philco Q-1710. I’m trying to find out the year it was made. I’ve been trying to research online but I cannot find anything! Does anyone have any info that they could share about this model?
Thanks!
It helps a lot if you post a photo. I'm guessing this might be a 1960s radio.
Hi there! I am having difficulty including a photo in my post. From what I’ve found, other Q models came out in the 60’s so I was thinking the same. I will continue trying to add a photo.
Hi and welcome,
Your Q 1710 dates from 1967 and is listed in Sam's Photofact #913-7.
GL w/your project!
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
There are currently 474 online users. [Complete List]
» 1 Member(s) | 473 Guest(s)
