Philco 76 output transformer #2848
Threads: 10
City: Memphis,Tn
So I have the field coil done(my first), But I also have an open side in my output transformer. Since I have not been able to find a suitable replacement, I am thinking I will attempt to rewind. I am NOT up on transformers. After watching and reading everything I can find, I came up with this conclusion. This transformer has an 80:1 ratio. 80 turns on the primary to every 1 turn of the secondary. Now if I copy that, as best I can, will that work?
Stan
(This post was last modified: 12-10-2020, 09:46 AM by Stan the Man.)
Threads: 270
You may want to have a look at this: https://philcoradio.com/phorum/showthread.php?tid=17572 around post 12/13 or so. Most of it's abt the input transformer but the mechanics of it is the same. Take it apart, count the turns and layers rewind accordingly.
Threads: 10
City: Memphis,Tn
Thank you for the link, and the reply. I unwound the primary yesterday. It was not pretty. The transformer was impregnated with a waxy substance, and there were spots of corrosion all over. As soon as I would get it started unwinding, it would break. It became impossible to count turns. And by that time I was so aggravated, I forgot what layer I was on. Now I have a clean-er core, and a nice secondary winding. All I need is the primary.
Stan
Threads: 32
City: Wellborn Florida
You know the wire size might take all the pieces of the pri. wire and measure the total length add enough for few extra turns and give it a try. Much easier to remove a turn than add a turn. Gook luck David
Threads: 10
City: Memphis,Tn
David,. I'm gonna say the wire is 38ga. As for measuring the length, I would say thats not possible now. I can still see the imprint of the wire on the core. So I know how wide the layers will be. I can easily count the secondary wire turns. So I should be able to come up with something close. I just wanted to know if I was on the right track.
Stan
Threads: 32
I have not looked but is there a spec on the resistance of the primary if so then look up the resistance per 100 feet of 38 ga or something like that an guess at the length add a little extra. Stay Safe David
Threads: 574
Stan, get a Core!
Threads: 10
City: Memphis,Tn
I don't seem to be able to find a spec for the transformer, other than its 80:1 ratio.
My core is still very much intact, with the secondary still in it. I have ordered wire, and I have a cheap coil winder, so we will see what happens.
Stan
Threads: 112
City: Medford OR (OR what?)
Threads: 270
Ed sez: I'm now finishing up the O/P transformer. Primary is done (#35 wire, 20 layers of 140 turns each with center tap). The secondary will be next. That is 18 AWG - incredibly beefy considering the voice coil of the speaker!
This = a primary of 5.2k load for the p/p 42's in a triode reconfiguration (Ed's 16X). Your 45's require a bit of a lower load abt 3.2k so a little less wire/turns. [Image: https://philcoradio.com/phorum/images/sm..._smile.gif]
(This post was last modified: 12-11-2020, 11:42 AM by Radioroslyn.)
Threads: 54
I was going to suggest cleaning up the old wire from the wire from the primary, removing the wax, and weighing it. That's an alternative method to measuring the length if you can figure out how much a foot of a given gauge of wire weighs, though it is not easy without something like a chemist's scale.
Threads: 10
City: Memphis,Tn
Arran, The thought did occur to me. For reference sake. Whatever is on that wire was all over my hands by the time I was finished. What a sticky mess. If I thought I would be able to clean the wire and get a good weight that might be worth a shot.
Stan
Threads: 112
A person generally does not have to worry about getting too much wire on the form unless they use much smaller wire. If laid down neatly in layers, there is generally enough space. If bulk wound or wrapped with anything thicker than stock - no way.
Threads: 10
City: Memphis,Tn
Threads: 10
City: Memphis,Tn
Since you stated earlier, you have a console 38-7XX. They also had a 38-7T (table), and 38-7CS (chairside). A very nic...GarySP — 01:18 PM |
That I wouldn't know, but sometimes the radio document itself shows one, same as the capacitor cans' etc pinouts.morzh — 12:46 PM |
Thank you morzh, that is exactly what I was looking for. Now , is there some where that shows pinouts for Philco power ...Jim Dutridge — 11:37 AM |
Thanks for your help Michael. In fact, this video is only an intermediate result. Later I had to apply another tinting l...RadioSvit — 09:01 AM |
Great job on the cabinet.
PS. In the US notation, "kenotron" refers to specific type of tubes; we call re...morzh — 08:24 AM |
This document has at least some tables of models and parts used.
Example: Choke 32-7572, used in 604 radio.
Search f...morzh — 08:19 AM |
I also checked all the radio tubes on my Hickok 530 tube tester. The 5Z3 kenotron turned out to be faulty, all the other...RadioSvit — 08:02 AM |
Well... While the varnish is drying up, I started repairing the chassis...
Of course I started by replacing the pa...RadioSvit — 07:12 AM |
Hello Martin,
Welcome aboard our little community what great Model 38-7
Sincerely Richardradiorich — 12:30 AM |
Welcome to the Phorum Martin.
I count about 9 paper caps, the 3 electrolytic caps and 2-Y2 safety caps to replace th...RodB — 09:44 PM |
There are currently 1287 online users. [Complete List] » 1 Member(s) | 1286 Guest(s)
