Model 60 stain color
45philcodon Wrote:Please explain your comment regarding polyurethane. Why would this be a problem if I plan to totally strip the cabinet?
Please read the link Russ provided just above to his blog (post #15, first page, this thread). Russ is an expert cabinet refinisher as well as a great restorer overall and he knows what he is talking about. As he says, removal of polyurethane is a really slow pain. Icon_thumbdown And it requires MEK strippers which have been mostly pulled off the market because of idiots who were stripping indoors and killing themselves with the resulting noxious fumes.
I heard that the German sets often used polyester resin, kind of like fiberglass gel coat . In any event I think it's catalyzed, whatever the stuff is,  and hard to get off. I wonder if scuffing up the surface of either would make it easier to strip off, with something like steel wool or a finer grit of sandpaper, that trick works on stripping off powder coating that has gone bad.
There was a product that I used fifteen years ago that would strip anything, including polyurethane products. It was bio-degradeable, water soluble, essentially odorless and could be left to dry on a surface, then wetted and reactivated without damage. Sounds too good to be true? It was EXPENSIVE, but it worked ...
It was called Multi-Strip-Pro and came from a company called "Back To Nature". I don't know if its still available in the USA. It appears NOT to be in Canada :
https://www.sunnysidecorp.com/products.php?p=r
New find. 91X code 225
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
There are currently 1271 online users. [Complete List]
» 1 Member(s) | 1270 Guest(s)
