Philco 89 bypass capacitor voltage
I'm working on a Philco 89 (code 123) and I'm ready to replace the 5 bypass capacitors in the metal can under the chassis (part no. 4). They are .05,.05,.09,.09 and .25 uF.
I have some capacitors of those approx values rated at 200V. Can I get away with that voltage? or do I need to get capacitors with a higher voltage?
Mark Icon_problem
Yes and no Icon_smile For #4 and #39 200v would suffice but for the other three you really should use 400v or higher.
Thanks for the help.
One more question, if I may, at the risk of showing my electronic ignorance....
There is a bakelite cap block no. 17 which has two 0.09 caps in it. One is labeled 17 on the circuit diagram while the other is labeled 29. It is unclear to me if I can use my 0.1uF, 200V capacitors to rebuild that block??
Mark
Yes, on both caps. There's minimal voltage on both of those. Without doing math its probably about 20 volts or so. And 0.1 is fine to replace 0.09. Philco did some funny things like noting "99k" resistors instead of 100k because of poor factory lighting. I suspect that their choice of "0.09" was intended to mitigate reading errors between 0.1 and 0.01
Thank you exray. I can continue with my rebuilding now.
Mark
Hi again, Mark.
Next time buy all 630v caps and this will never again be a question! A few cents more but at the price for shipping when you only need onesie-twosies you'll be better off in the long run.
exray Wrote:Hi again, Mark.
That's good advice and what I usually do. I happened to run out of my 630V caps and was scrounging through my supplies when I found a bunch of 200V and 250V caps.
That's what prompted the questions along with my limited knowledge of electronics.
New Philco Repair Bench
Morzh is correct. The repair bench on our website is an archived image of chuck’s original site. He no longer provides s...klondike98 — 05:32 PM
Excellent information. It is all starting to come together now and your explanation really helped since I noticed that ...georgetownjohn — 04:39 PM
Hi John, I don't have this radio, but I can supply some info: Based on your pic, pins 7,8 and 1 are used together, go...MrFixr55 — 02:02 PM
As far as I know, the Repairbench does not work, and has not been working in a while. Chuck (we had that campaign looki...morzh — 01:33 PM
Radio city products 664 schematic request
Need a schematic or manual for the 664. The 663 may be similar.daveone23 — 12:38 PM
Thanks Gary.dconant — 12:16 PM
I tried accessing the site through our library and got the same response. It's reported to our tech gurus. GaryGarySP — 11:50 AM
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
There are currently 5730 online users. [Complete List]
» 3 Member(s) | 5727 Guest(s)
