Model 70 1st det. coil
Hi All,
I'm working on a model 70 and I have an open primary winding on the 1st detector transformer- Philco part no. 03083 item number 6 on the schematic. Does anyone have the info on how many turns, which direction and gauge of wire? Any info would greatly appreciated! Thanks!
Took a quick look at the diagram and the winding you are looking to rewind is a non frequency determining (untuned) The number of turns is not real critical. What I would do is use some #36-38G wire. Rewind to fill the same space of the original. I would suspect it's about 55 turns. You can determine the direction when you remove the old one.
Thanks for the info Terry! I pulled the coil out and found out the direction (should have thought of that earlier!). I've measured the width of the winding and will try to count the turns.
Kevin
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
