  • 1 Vote(s) - 5 Average
16B Cathedral Cabinet Restoration
[Image: https://live.staticflickr.com/65535/5134...25e0_c.jpg]
I use this fixture for clamping veneer to wraparounds. In this case, I am using it to clamp the wrap while re-gluing the inside veneer.
M R Radios   C M Tubes
[Image: https://live.staticflickr.com/65535/5133...3ec2_c.jpg]
All of the delamination has been re-glued, the extra holes plugged, the inside veneer patched and the outside sanded. The wrap is now ready for veneer.
[Image: https://live.staticflickr.com/65535/5134...a7e2_c.jpg]
Gluing the veneer. I use yellow wood glue thinned with water, about two and a half to three parts glue to one part water, I use the TLAR (That Looks About Right) system on that. I brush a coat of glue on about the top third of the wraparound and on the veneer. In this photo, The glue has been applied, the wrap and veneer have been placed in the clamp fixture. The bolts at the bottom will now be tightened (there are four on each side). This will pull the band down tight and clamp the veneer. There is a layer of felt on the inside of the band and also under the wrap, this insures an even clamp pressure. The clamp fixture doesn't apply much pressure to the lower side portions of the wrap so, only the upper curved portion is glued in this fixture. After the upper part has dried, the wrap will be removed and the lower side portions will be glued and clamped using flat clamp boards.
I have been away for a few days so not much has been done.
[Image: https://live.staticflickr.com/65535/5134...7502_c.jpg]
The original wraparound after re-veneer. I am going to spray the lacquer on the wrap before installing because sanding is difficult in the area where the wrap joins the front arch after it has been installed.
[Image: https://live.staticflickr.com/65535/5136...ece9_c.jpg]
Reinstalling the wraparound
[Image: https://live.staticflickr.com/65535/5135...acea_c.jpg]
It's starting to look like a 16B again!
Icon_clap Icon_thumbup
It's lookin' pretty!
Icon_thumbup Icon_thumbup
Thanks, guys! I will probably have a few more photos this evening.
[Image: https://live.staticflickr.com/65535/5135...8216_c.jpg]
The rear arch support in a 16B cabinet is pretty large so, it takes lots of clamps! Note the piece of scrap under the clamps to protect the wraparound.
[Image: https://live.staticflickr.com/65535/5136...a834_c.jpg]
The stiffeners being added to the back edge of the sides.
[Image: https://live.staticflickr.com/65535/5136...e79d_c.jpg]
The gussets have been added to the inside of the cabinet
[Image: https://live.staticflickr.com/65535/5136...da17_c.jpg]
I decided to replace the original base as it was in really bad condition. The new base has been fit to the cabinet. I will finish all the moulding before installing. I am now ready to start spraying lacquer.
What a great job! Thanks for posting your progress.
I have had a few things going on so, the cabinet work has been a little slow. Getting back to it now.
[Image: https://live.staticflickr.com/65535/5140...ebab_c.jpg]
I have sprayed the toner and installed the moulding
[Image: https://live.staticflickr.com/65535/5142...ee98_c.jpg]
New brass feet have been installed
[Image: https://live.staticflickr.com/65535/5142...811b_c.jpg]
FINISHED!
Clear lacquer has been sprayed and the cabinet has been assembled. I have some work to do on the chassis before installing. That probably won't happen until winter.
[Image: https://live.staticflickr.com/65535/5131...9dca_c.jpg]
Again, the before picture.
Very nice!!
Beautiful!
Icon_clap Icon_clap Icon_clap
Wow! Looking at the "after" photo, one would not believe that it once looked as it did in the "before" photo.
Great work as always! Icon_thumbup Icon_thumbup Icon_clap
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
There are currently 845 online users. [Complete List]
» 2 Member(s) | 843 Guest(s)
