37-116 - Installing Grill Cloth - How?
I'm trying how to install grill cloth for my 37-116.
I don't particularly want to glue it where it would be visible in the center opening in the cabinet. But, I'm not sure that's possible. The cloth will pass over the two, side, "clarifiers" where there's no surface to glue it to. The original cloth has the chevron pattern repeated on the sides so it could be simply be glued along the edges of the board. I roughly outlined the center opening in the photo so I can sit here at my desk and stare at it...
Any suggestions would be appreciated. I've actually thought of putting a piece of wood across the clarifier openings to give me something to glue it to. Looks like the clarifiers are covered some by the cabinet anyway.
Greg
Greg O.
Whitehall, PA
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
