Speaker
Anybody got a picture of an original speaker that went into a 1932 52b Philco Cathedral I assume it was a 5" Electrodynamic
Doubt whether I would get a working one to install
Hi Peter,
I don't have a 52b in my collection, but I believe that it uses the same style of speaker as the 80b.
Hi Peter and welcome
Here are some pic of the 6" speaker from a model 81. It's physical identical the one that was fitted to your set. You can go here: https://www.philcoradio.com/phorum/showt...hp?tid=215 Go to spkr zip and open the file. Within there is the specs most of the Philco speakers pre 1937 or so. What you looking for is a P2 speaker. It will tell you all about the speaker. It's also listed in the library but it's not as extensive.
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
There are currently 7566 online users. [Complete List]
» 1 Member(s) | 7565 Guest(s)
